700 EFI Sportsman smokeing belt
Old Sep 5, 2005 | 09:39 AM
ftwflh's Avatar
Default 700 EFI Sportsman smokeing belt
My riding buddy has a new 700EFI and every time he gets in a mud hole in high gear he smokes the belt(these are mud holes I take my Scrambler through first) What do you all think could be wrong with this tank?
Old Sep 5, 2005 | 10:13 AM
Mudlover600Tw's Avatar
Tell your budd to always put it in <U>low </U>gear too much torque in mud and will always smoke the belt my 600 does it in high gear as well.Run in low and GIVVER he wont get stuck.
Old Sep 5, 2005 | 11:35 AM
spyder6's Avatar
no offence, but your buddy is an idiot. whenever in any situation that requires torque or yoru moving through thick stuff, use LOW RANGE
Old Sep 5, 2005 | 01:02 PM
drlang's Avatar
The scrambler doesn't have low, is there that much of a power difference on these things?
Power to weight ratio I suppose.
Old Sep 5, 2005 | 01:05 PM
rieds's Avatar
the sportsman weighs at least 150 pounds more than your scrambler
Old Sep 5, 2005 | 01:15 PM
jayri's Avatar
Sportsman also has much larger tires to turn.
Old Sep 5, 2005 | 03:05 PM
jimmypsp700's Avatar
If he's splashing in at a higher rate of speed he could be getting some water in the PVT snorkle.
I would also use low, unless its real wet soupy mud like a pond.
Old Sep 5, 2005 | 06:38 PM
cornbread2's Avatar
As a general rule if you must put it in 4 wheel drive it needs to be in low.
Old Sep 5, 2005 | 10:55 PM
ftwflh's Avatar
I rode the thing today and the belt slipped in 2wd going up a small ditch bank.And I KNOW how to ride a CVT.
Old Sep 6, 2005 | 12:19 AM
Polaris500HO4x4's Avatar
has the belt been replaced?
