Upgrades to my CAT 650 V2
Old Sep 6, 2005 | 01:30 PM
V2Otter's Avatar
Default Upgrades to my CAT 650 V2
I recently purchased a new Artic Cat 650 V2 with 28" ITP- 2500lb. Warn Winch - Great Machice.
However, in using this machine to pull some heavy logs I smoked the belt. (lesson learned). So, my first question is what's the best-best replacement belt for the CAT? My second question is what CDI module should I get for more horsepower? I'm not looking for a faster machine but a more powerful machine. (I will be using it to plow snow and ice fishing).
I am seeing alot of posts about changing primary springs to increase belt life... Can anyone tell me the model numbers of the spring to replace.
Thanks for all your help in advance.
OTTER
Old Sep 6, 2005 | 08:12 PM
DaveB's Avatar
Take the secondary apart and remove the smaller of the two shims. Put in an EPI Black spring in the secondary and a Prairie 700 primary spring in the primary....or an EPI Pink.
Old Sep 9, 2005 | 01:25 PM
alwaysride's Avatar
stick to stock belts. Dont get like a dayco or whatnot. THe quality is better with stock kawis. Were you using low gear, if not, make sure you use low gear as much as possible.
Jmuddin284
Jan 19, 2026 07:16 AM
jankerstien
Sep 21, 2015 03:09 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Brandon400
Sep 5, 2015 08:44 PM
XxS0ccerstarxX
Aug 27, 2015 02:31 PM
