Blaster Boging out at high power
Old Sep 7, 2005 | 10:00 PM
blasterguy4012's Avatar
Default Blaster Boging out at high power
Well as you might of guessed I have a 2000 Blaster. The problem is that when I accelerate to higher throttle positions the motor speeds up like normal. After a few seconds it begins to sputter and die. If im going fast enough and I let off the throttle it will begin to catch its self after the throttle drops to lower speeds. I have a fmf pipe and scilencer and have jeted it with a 40 size main jet. The top end was rebuilt however I was having the same problem before the rebuild. Anything that you could think of would really help
Old Sep 7, 2005 | 10:36 PM
blasterchild's Avatar
Float level is too low, im almost postitive. set your float hieght and check back with results.
It could also be a clogged petcock, take the hose off of your carb, turn the gas on, if it just dribbles or flows very little then thats most likely your problem.
~jim~
Old Sep 7, 2005 | 10:52 PM
Thanks for the quick reply. I will try that tommarrow, Long day today. lol Thanks and I will post back
Old Sep 9, 2005 | 05:21 PM
fastquad02blaster's Avatar
That soulds like float level to me also.
Old Sep 10, 2005 | 09:27 PM
Your good, Na really it was the float. It was way out of wack. Fixed it and it now runs great.
Old Sep 15, 2005 | 06:08 PM
Tedders's Avatar
i am having the same problem with a friends blaster i was wondering how you set the float height
thanks
Old Sep 17, 2005 | 09:18 AM
I'll see if I can explain it, Remove the carb from the engine. Remove the 4 screws from the bowl, hold the carb upside down so that the floats are facing up. Measuring from the gasket to the top of the float should be 20 -21.5mm. Just bend to ajust. Hope that helps somewhat.
Nondem
Feb 22, 2020 12:20 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
joeyupton
Jul 14, 2015 11:51 AM
Chocobamofo
Jul 10, 2015 07:46 PM
