Raise engagement
Old Sep 9, 2005 | 02:31 AM
snowdust's Avatar
Default Raise engagement
I have a predator 90 that has the 28mm carb and pipe and porting by hetrick. I drilled out the shoes and am using red springs. I want to get the engagement a little higher. Do they make stiffer springs than the red? Anything else I can do?
Old Sep 9, 2005 | 10:54 AM
LT80's Avatar
LT80 Expert
Reduce the roller weight and/or drill the shoes more.
Old Sep 9, 2005 | 01:13 PM
Fastestdad's Avatar
Get an ultralight rear clutch it'll engage as high as you want it to. They are about $75 to $150 I got one from Billy at WRH Racing for about $100 and one here locally at a shop for $75 billys is maybe a little better made. They pull nice and hard off the line but not good for trails due to heat.
Old Sep 9, 2005 | 01:17 PM
snowdust's Avatar
Fastest... Can you explain the heat build up on the aftermarket one? It just doesn't take heat well??? Or creates more heat?
Old Sep 10, 2005 | 10:07 AM
LT80's Avatar
LT80 Expert
Lighter weights spin more on the hub, thus more heat.
flyin-lowe
Dec 1, 2017 03:18 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
