2000$ what do you think?
Old Sep 9, 2005 | 08:02 AM
slidesquad's Avatar
Default 2000$ what do you think?
ok i have decided that the 2 grand in my pocket is going into my raptor this is what i was thinking tell me if you would do it different
elka suspension not the full race one just the average one front and back not sure on price was thinking it would cost 800$?? info on prices
ct racing pipe and k&n filter with outer wear 500$
nerf bars 170$
sand-sports rear axel spacers 100$
need sand tires for Pismo only a few trips a year i was thinking sand stars??? 170$
steering stabilizer i found some decent ones for 160$
and the trail tech 100$
is this the correct price on every thing? and what should i do/not do
any info would be nice and a place for the suspension at a good price would be cool also
Old Sep 9, 2005 | 04:31 PM
recon99's Avatar
I am going to assume you do some jumping when you ride because you want elkas. If you hit jumps more than a couple feet high I would suggest that instead of putting wheel spacers on the thin stock axle that you spend a little more and get an aftermarket axle instead. My neighbor had a 660 for a while, which had wheel spacers on it when he got it. He ended up bending the rear axle from landing a little sideways off of a jump about 3-4 feet high, which wouldn't have bent an aftermarket axle or the stock one without spacers. I suggest the g-force axle because of the cost, and it seems just as good as a durablue eliminator. Rockymountainatv has them for 200+shipping rockymountainatv.com - gforce racing axle
Old Sep 9, 2005 | 06:03 PM
slidesquad's Avatar
ok i guess i will fork over the extra money for a axel i have been tring to get around that but it isnt working lol is there a cheep way to widen the fronts besides offset rims?
Old Sep 9, 2005 | 08:01 PM
recon99's Avatar
For my warrior I flipped the original valve stem on the wheel so the stem is inside of the rim, then I drilled a hole on the other side of the wheel and put a new stem in, and installed the wheel flipped opposite of what it would normally be, which widened it up 3-4 inches for a couple bucks. I think this will work with all yamahas. Pretty much converts your stock rim into an offset rim, the only side effects are you get more bump steer than usual, and the shock will be softer. Same thing as wheel spacers do. I actually did this for the front and rear of my warrior right after I bought it and it's still working great. You can see how much wider mine is than a stock warrior in my pics
Old Sep 9, 2005 | 09:11 PM
garrett5462's Avatar
get the trailtech, i have one and i like it, its pretty intersting finding out your speed, distance and what not.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
