High RPM misfire
Old Sep 10, 2005 | 06:39 PM
Raptor69's Avatar
Default High RPM misfire
I have an 05 Raptor that I put an HMF full exhaust system on. I've run it without jetting it and it ran just fine. When I put the recommended jets in it (150 Left, 155 Right) I noticed a misfire in the high RPM's. We tried adjusting the air mixture and did all the recommended adjustments but got no change. If anything, it got worse. If I shift gears sooner it doesn’t happen. Anyone have any suggestions?
Old Sep 10, 2005 | 10:35 PM
Doctorturbo's Avatar
GOT BOOST!
Your lean, fatten the main up. To see if I'm right, pull the choke on slightly and take it for a pass. If it cleans up you need to fatten it up.
Old Sep 12, 2005 | 12:03 PM
Raptor69's Avatar
Thanks for replying to my post Doctorturbo. I've tried you idea already but it still has the same problem. We think we may have gained so much horse power that I'm hit the revel emiter a lot sooner. As I said before, if I shift gears sooner it dosen't happen, that is until I peg out in fifth gear.
Old Sep 12, 2005 | 04:25 PM
skii0's Avatar
is all you have on it is a hmf pipe?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
