Warrior Motor Mounts
Old Sep 11, 2005 | 03:15 PM
warriorman95's Avatar
Default Warrior Motor Mounts
Okay I had a bad poping going on with my chain and my dealer said wore out rear sprocket so i got a new one. Didn't fix it. Other day i noticed motor was moving when i revved the engine. Looked and all bolts were in mounts, but top one was broken. Anyone else had this problem, what did you do to fix it? I been wanting to get my frame powder coated blue, so is this a good time to strip the bike down to fix those mounts. Do you think because the motor is moving that the chain is just getting out of line and trying to come off?
Old Sep 11, 2005 | 04:20 PM
UltimateAussie's Avatar
well it could be the problem with your chain, but i know that to fix the top mount you dont have to strip down the bike you just have to take off the petrol tank, becuase mine were broken right throught the middle of the bolt hole. i just put a washer on the outside of the mount and then welded it up and then ground it smooth on the inside, sandblasted it and then i painted it and then i put it back on, hope this helps
Old Sep 11, 2005 | 05:33 PM
Yeah mines broke at the same place, right in the middle of the bolt hole. Did your chain pop or try to come off when yours was broke?
Old Sep 11, 2005 | 06:54 PM
no do you have the little ployurethane chain guide on yours. im not sure if they come stock or not but i had one on mine when i bought it. i never had the chain derail
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Kaleb_00
Jun 1, 2016 09:15 AM
quickwhips
Sep 2, 2015 06:53 AM
WesTech
11
Aug 11, 2015 07:55 AM
