Help
Old Sep 12, 2005 | 10:42 PM
wrangler89's Avatar
Default Help
I have a honda 4 trax 300 the carb started leaking out the bottom can anyone tell me how to fix.2000 model
Old Sep 13, 2005 | 12:58 AM
450r's Avatar
Default Help
where at on the bottom of the carb?around the bowl(gasket), out the big plug in the bottom, need to be a liitle more specific.
Old Sep 14, 2005 | 12:24 AM
wrangler89's Avatar
Default Help
It is leaking out bottom of carb on bottom past float valve. I have already replaced the little valve past the float it still is leaking.Thanks Keith.
Old Sep 14, 2005 | 02:38 AM
450r's Avatar
Default Help
float valve ? the only thing i can think of, unless there is a term youre using i'm not familiar with, is the fuel inlet wich is shut off by the floats (sort of). is it leaking past some sort of screw(fuel screw).you'll still need to be more specific. do you have a digital camera?
Old Sep 14, 2005 | 11:00 AM
wrangler89's Avatar
Default Help
It is leaking out the bottom of the float bowl out the drain tube.You can go to bike bandit and pull up diagram of 2000 honda fourtrax 4x4 300.
Old Sep 15, 2005 | 01:48 AM
450r's Avatar
Default Help
if it is coming out of the DRAIN tube then just plug the tube. the only thing a drain tube is for is exactly that draing the fuel out of your carb ,mostly for storage.if it's the OVERFLOW tube then your floats or float valve(shut off) is stuck,and you'll need to remove the carb and clean it. sometimes you can just tap on the side of the carb and they'll (it) loosen up for a while.
Old Sep 22, 2005 | 04:36 PM
wrangler89's Avatar
Default Help
Thanks that what it was dirty float bowl.
Old Sep 23, 2005 | 11:04 AM
450r's Avatar
Default Help
[img]i/expressions/face-icon-small-smile.gif[/img]
