Honda TRX 250R Frame
Old Sep 16, 2005 | 02:48 AM
URCRAZY's Avatar
Default Honda TRX 250R Frame
I have a 250R and the guy I bought if off said it was a 89 gusseted Lonestar frame, but it looks like a stock, maybe gusseted by Lonestar? Would lonestar mark a symbol if they did that, and how can you tell the difference between the 86 and 89 frames?
Old Sep 16, 2005 | 03:36 PM
Hoppedrap's Avatar
From the side pic the motor mounts look like an 86, can you post a better pic of the frame
Old Sep 16, 2005 | 10:18 PM
lbc's Avatar
lbc
If it is a lonestar frame it will be round tubular steel. If it is not round tubular steel it is a stock frame thats possibly been reenforced or gussetted by lonestar. Also if it is a lonestar frame it will be stamped lonestar on the top of the shock supports.
Old Sep 17, 2005 | 04:11 AM
URCRAZY's Avatar
No cant post any other pics. cameras broken. How do you tell by an 86 or 89 frame by the engine mounts or where else? It is a stock frame, but Iam not sure if it was gussetted by Lonestar or even gussetted at all.
Old Sep 17, 2005 | 06:47 PM
lbc's Avatar
lbc
Frame to frame no difference. Geometry yes. On the 86 everything sits further back by about 1 1/2". A-arms, steering stem, footpegs. Swing arm is about an inch shorter.
Old Sep 18, 2005 | 01:27 AM
TractorPacker's Avatar
Do you have a balloon?
Couldn't you give the serial # to the Honda shop and check the year. That sort of this is usually a code sequence, in a VIN.
Old Sep 18, 2005 | 04:32 PM
1BAD250R's Avatar
The 86 frame will have solid metal front motor mounts whereas the newer years had metal flaps that were not quite as beefy. Also, unless it has been converted, the 86 frame does not have rear motor mounts connected directly to the frame. It has a plate with mounts that slips between the swingarm then connects to the motor. The 86-87 R swingarm was one inch longer than the 88-89, not shorter.
The 86 frame VIN #s are GC000013 to GC021064.
The rest of the frame VIN #s can be found on macdizzy.com
Old Sep 18, 2005 | 07:44 PM
URCRAZY's Avatar
Are the vin #'s on the front of the frame where the stem is or are they under where the motor is??
Old Sep 19, 2005 | 01:27 AM
1BAD250R's Avatar
Should be on a small plate on the left side of the subframe.
DFWSRT8
Aug 20, 2015 09:24 AM
MNatv89
Aug 12, 2015 06:00 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
