Its making a wierd sound
Old Oct 24, 2000 | 10:33 AM
answer250r's Avatar
MY 250r is making a weird sound. When i satrt it up and let go of the cluthch it stalls. i think there is somthing wrong with the transmisson. Also somtimes It will not kick over. I have to put it into gear and rock it to free it up. Can anybody help me!!
Old Oct 24, 2000 | 04:42 PM
nik's Avatar
nik
Sounds like there may be some kind of foreign body in the clutch housing thats causing the gears in there to jam up. Try removing your clutch casing (right hand side as you're sat on it). Examine your gears inside there for any damage or play in the shafts. If you need any more info on dissassembling it I can find my manual but offhand I can't remember. You may have to take the water pump cover off first but I'm not sure.
Regards,
Nik
ATC250R 86'
ATC250ESF 85'
Fantic 300 87'
Bultaco 360 74'
Old Oct 25, 2000 | 01:24 PM
answer250r's Avatar
ITs an 81 I starting to think it might be the main bearing but my father seems to want to split the crank case open do you think that I will have to do that thanx again
Old Oct 25, 2000 | 04:24 PM
nik's Avatar
nik
It is always possible that it could be the main bearing but it would have to be well gone to lock up. It would seem more likely it was gear trouble with the symptoms you described. Have a look inside the clutch case if you can't find anything take of the cylinder head and barrel then check for any play in the crank you should soon be able to tell if it's the main bearings. If so it'll need splitting but to check the clutch case will only take an hour tops and not much longer to take the barrel off for a look.
Good Luck
Nik
Old Oct 26, 2000 | 06:13 PM
answer250r's Avatar
Ok thanx alot nik
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
cSchwartz
Jul 12, 2015 07:42 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
D-Hagz
Jul 4, 2015 02:19 AM
