ATV wont run (wiring diagram)
Hello. I am having an issue with a 200cc china quad I bought recently.The motor just wont start. It wont make any sound when I press the start button.. I realy have no clue what to do.. Maybe something is wrong with the wires, so I made Today a wiring diagram, can anybody see what is wrong?
Nice diagram, it should help others, especially if you can give us a makers name. Do you get a click from the solenoid? If not, put a test lamp across the green/yellow wire and the brown wire going to it, press the start button and see if the lamp lights, if it does you have a faulty solenoid. If it doesn't, connect the lamp to the green/yellow and the battery, the lamp should light on either the pos or neg. If it doesn't light on one of them, the fault is with this circuit, brake switch, relay? etc. If the green/yellow is OK the fault is in the brown, so trace that back to see if the switch is faulty.
The brake switch was broken, so I connected the two wires directly.. Now the brake light is shinig
Thank you.. It is a Bashan 200cc ATV... I will try your recommendation with the lamp like you said, and reply the results.. Now that you mentioned it, yes the solenoid is clicking... what does this mean?
