carb repair kit
Old Sep 23, 2005 | 02:39 PM
CHacHie1226's Avatar
Default carb repair kit
does anybody know where i can get a carb repair kit for an 01 250 2x4? Moose utilities doesnt cary them and the float in my carb is sticking.
Old Sep 23, 2005 | 08:43 PM
Bear4570's Avatar
Arctic Cat only sells the pieces seperately so you only buy what you need. The last two times into my carbs have only been dirt causing the problem. The "o"rings are reusable so it was just a matter of tear down, clean and reassemble.
Old Sep 23, 2005 | 09:01 PM
is there any way you could somewhat walk me through that?
Old Sep 23, 2005 | 09:40 PM
Bear4570's Avatar
I have the service manual for the 2001 250 and can e-mail you the pages for the carb teardown, inspect and reassembly. If you pm me you e-mail address I will send them. Then you will have the words and pictures to follow.
Old Sep 24, 2005 | 02:58 PM
Bear4570's Avatar
CHacHie1226; You have mail. It is a rather large zip file and if it doesn't come thru let me know and I will do it differently.
Old Sep 29, 2005 | 03:48 PM
geoids's Avatar
Did you ever find the carb parts anywhere on-line? I've got the same machine - my float needle isn't sealing -
Old Sep 29, 2005 | 08:07 PM
Bear4570's Avatar
For on line part numbers for AC machines go here.
http://www.alpha-sports.com/arctic_cat_atv_parts.htm
Then you are going to need to find a Mikuni or a Keikin carb dist or dealer depending on your model year.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
