CRF cam in 450R
Old Oct 2, 2005 | 08:49 PM
RoostinRaptor's Avatar
Default CRF cam in 450R
is the hrc cam the same as the CRF cam. will the CRF cam work in the 06 450. i have an 06 CRF and TRX and would like to know if it would be a good idea to put the cam from the CRF in the TRX.
Old Oct 2, 2005 | 11:11 PM
Torbinx's Avatar
the 06' trx is basically the crf engine exactly and it has the crf cams. hrc and crf cams are diff. The hrc cam for the 06' trx may be diff from the 05' and lower but if you want a more performance cam just look at cams for the crf and stick it in your quad [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 3, 2005 | 09:00 PM
sorry but im going to have to disagree with that. The cam in the CRF is different it has high profiles and will give it different power caracteristics. the trx has a lot of low end were as the crf has a lot of mid and top.
has any one tried the crf cam in there trx and what was the out come. thanks
Old Oct 3, 2005 | 10:10 PM
White7's Avatar
heres some interesting specs
Brand----------Int Lift/Exh Lift -- Int Dur/Exh Dur -- Lobe Cntr Int/Lobe Cntr Exh
Stock _______.357 __ .290 __ 230deg _ 230deg ___ 105deg _ 105deg
HRC ________.390 __ .350 __ 260deg _ 260deg ___ 110deg _ 105deg
02 CRF______ .380 __ .356 __ 249deg _ 272deg ___ 106.5deg _ 107deg
Hotcams 2 ___ .397 __ .342 __ 248deg _ 268deg ___ 109.75dg _ 105.5dg
Hotcams 1 ___ .378 __ .342 __ 237deg _ 268deg ___ 109.75dg _ 105.5dg
Megacycle X2_ .412 __ .350 __ 260deg _ 268deg ___ 108deg _ 108deg
Web 613/812__.381 __ .357 __ 240deg _ 258deg ___ 110deg _ 104deg
(designed for the TRX) *Designed to increase overall power. Excellent acceleration.
Web 613/729__.381 __ .342 __ 240deg _ 252deg ___ 110deg _ 104deg
Web MYSTO___.432___.350 ___293deg___296deg >>>@.50 260deg_260deg
Web 208/921__.408___.342___ 282deg___298deg>>>@.50 258deg__262deg
Johnson_____.400 ___ .375 ___ 266deg __ 284deg
Old Oct 4, 2005 | 12:14 PM
coryatver's Avatar
The 06 HRC kit comes with the CRF cam. The stock cams in the 450r are not CRF cams. The 05 450r HRC is not the CRF. Go here and click on the hrc kit video if you dont believe me.http://www.atvscene.com/machines/hon...test450-06.htm
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Asaran
Oct 8, 2015 11:14 AM
Aug 5, 2015 02:10 AM
dorene
Jun 5, 2015 05:25 PM
