not your normal 500 KNOCK
alright, you have probably all heard of a scrambler 500 knocking at idle. so i ignored the knock mine made at idle. i have a 1999 scrambler 500, and just starting today i took it out for a ride and the motor started to bang not knock, BANG so i imedetly shut it off and put it away. what could cause this? its always knocked but NOT like this. i have always put the right oil in it and always changed the oil and maintained it. if you pull it over now with the pull start it will clink and clatter as each stroke goes up and down. any information on this toppic would be great
remove the clutch cover, then pull it over, see if the sound is coming from the clutches instead.
its more likely to come from the clutches than the motor. with the clutch cover on, it can easily sound like its a motor noise. if so, then the primary clutch might need a rebuild.
good luck!
X
good luck!
X
DITTO on what X said.But if you think it is in the clutch then take the primary (front clutch )off and start it.When the buttons in the primary are gone it will sound like a rod knock but it is alot cheaper to fix.
oliveiracarlos
Sep 7, 2015 03:39 AM
