Suspention????
Old Oct 3, 2005 | 10:12 PM
Topper's Avatar
Default Suspention????
I need to adjust my ride heigth on my DS. I read the manuel too. It looks like I need a special tool to tighten up the nuts on the top of the rear shock? Is this correct? Thanks...
Old Oct 3, 2005 | 11:14 PM
sam's Avatar
sam
YES!!! ..................J/k
A 20oz framing hammer ( or equivelent) and a long flat screw driver that can handle a good swating. swat the top lose, righty tighty lefty losee if I recall right. and then the seconed one they are very tight
Old Oct 3, 2005 | 11:32 PM
Topper's Avatar
Sooooooooooooooooooo, the tool is a hammer and a screw driver? I was thinking about going to my dealer and seeing if there is a tool that I can borrow. Who knows.............
Old Oct 3, 2005 | 11:51 PM
dsdrew's Avatar
I just jack it up..letting the suspension free hang...and turn the springs by hand..in which turns the nut..
Old Oct 4, 2005 | 12:40 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
YEA what drew said just frist lossen the top nut and then jack her up and have fun if she gets a tad tight a large set of channel locks will finish the job.
Old Oct 4, 2005 | 01:44 AM
DemonDS's Avatar
Use some oil on them, something like WD-40, that makes em easier to turn too.
Old Oct 4, 2005 | 02:03 AM
BlackHawk's Avatar
There is a special tool available, it is called a spanner wrench. In any case I have two and neither one works very well so you may as well use the hammer method - you probably already have the hammer and screwdriver. Once you bust it loose you turn the spring as described and you are good. Don't waste your time or the skin off of you knuckles trying to use the lame wrenches made for that, they hardly work.
If you want to buy one, Amazon has 262 different models:
Amazon Spanner Wrenches
Old Oct 4, 2005 | 07:10 AM
pads's Avatar
Instead of a screwdriver, I used a piece of brass so I wouldn't ding up the retaining nuts.
Old Oct 4, 2005 | 11:33 AM
Mrneg9's Avatar
My dealer used exactly that. Heavy hammer and very larger prybar/screwdriver. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Oct 4, 2005 | 12:57 PM
Topper's Avatar
Thanks everyone for your help. It looks like I will go a head and do it with a hammer and a brass (old) punch that I have. When I did all the messuring for the suspention, the quad goes down 7" with me on it with all me gear. Does that mean I need to adjust it so it will go down 4 1/2" to 5" for it to be correct? Thanks again for everyone's info! [img]i/expressions/face-icon-small-cool.gif[/img]
