Leaking carb
Old Oct 5, 2005 | 04:34 PM
swiftyrecon's Avatar
Default Leaking carb
Hi, Whenever i use my Recon i find that there is alot of fuel coming out of the drainage tube on the bottom of the carb, i have taken it apart and given it a good clean and inspection but i can find no problems.
I no that if you go up steep inclines it is meant to drain out as the fuel bulb rises but not when i am on flat ground ? also i cant seem 2 adjust it so im stuck ! i no there is alot of fuel going into the engine because if i hit the throttle it will die on me, i have found a leaning/richening screw on the bottom of the carb but i dont no which way to turn it. If anyone has any info please share it with me ! cheers.
Old Oct 5, 2005 | 05:43 PM
1bad450r's Avatar
Your float is sticking. Your air/fuel mixture screw doesn't have anything to do with fuel draining out of the carb. If a good cleaning didn't do the trick then go pick yourself up a good carb rebuild kit from your dealer and that should solve your problem.
Old Oct 5, 2005 | 05:58 PM
will do, thanks
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
