RPM???
Old Oct 6, 2005 | 11:11 AM
Topper's Avatar
Default RPM???
What RPM does a stock DS650 pull? Thanks in advance!
Old Oct 6, 2005 | 11:25 AM
ILivSD's Avatar
Default RPM???
Hey Topper, Good morning.
I don't quite know if I am reading your question right ?
But
I have my Dyno results here from my basically stock DS and are you asking what is the peak RPM where she pulls hard at ?
or
Where it starts to climb
I think its early and I can't read just yet ?
Where's my coffee ? Ahhhhh
OK
My bike is stock internally (Cam, piston, & compression) but she really starts hitting from about 4000rpm at (30 horse) till 7500rpm and peaks out at its max of 51 horse.
Is that what your looking for ?
Old Oct 6, 2005 | 12:10 PM
DaBomb650's Avatar
Default RPM???
Older DS's had a rev limiter at 7700 rpm, the newer ones I believe are limited 7900 rpm
Old Oct 6, 2005 | 03:01 PM
Bone1208's Avatar
Default RPM???
I have an 06 ds and the stock rev was around 7500rpm. I put the big gun cdi on and it hits the rev limiter around 8500rpm. Thats according to the stock rpm gauge.
Old Oct 6, 2005 | 04:02 PM
DuneRider650's Avatar
I ride a little here and there......
Default RPM???
all the baja x's rev at 7900 ur tach is wrong......
Old Oct 6, 2005 | 04:45 PM
Topper's Avatar
Default RPM???
Thanks for everyone's responce. I was looking for the rev limiter RPM. Sorry I wasn't to clear. It was early for me too. If they rev to 7900 RPM, why would a guy want it to rev higher? Wouldn't that be hard on the motor? Float the valves? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 6, 2005 | 06:08 PM
Default RPM???
They can handle 8 something if i remember right....when they get super high revs guys go to stiffer valve springs.
Old Oct 6, 2005 | 06:57 PM
ILivSD's Avatar
Default RPM???
Ahhhh, got ya Topper.
I have the 04BajaX with the stock bumped up rev-limiter and I still opted to put the (BigGun/Procomm) CDI on it because the bike just felt like it had more power to give at the upper RPM range. Hitting that rev-limiter at 7500 sucked when you haven't even topped it out yet ! Now my Dyno run shows the the power starts to fade after 7500 and at 8000 diveing pretty steep but its still there !!!. I don't think there's much more power to be had at the upper end of the power band on a stock bike. My self I don't feel the 300.00 CDI's give you all that much more performance compaired to the 100.00 dollar units but I hear the Mallory CDI's are pretty impressive.
I think the CDI's help a little bit on advancing your spark through out the entire RPM range but keep your stock one with you as I had my aftermarket CDI fail on me during the first few runs. I got it replaced and She is solid as Oak now... knock on wood.
I'm gone ....
Old Oct 7, 2005 | 02:15 AM
NickDS650's Avatar
Default RPM???
redlines at 8500 i do believe
