how bad did i screw up?
Old Oct 10, 2005 | 07:13 PM
wrestleu's Avatar
Default how bad did i screw up?
Well, this weekend I put the engine back together (185S). As I worked my way up, I noticed that the last remaining gasket was the wrong one. You know how the two cylinder gaskets are, and one has a notch out where the cam chain is. Well apparently not paying attention I put the one WITH the notch out at the bottom and the one with the notch for the top. Should I tear it back down and redo it or will it seal? I'm thinking I might leave it, but I probably know better...any input would be great. Thanks.
Old Oct 11, 2005 | 02:15 PM
ThrashAndCrash's Avatar
I'm a little confused........There is a paper base gasket...then a thick head gasket.......Did you put the head gasket where the base one goes??
Old Oct 11, 2005 | 03:58 PM
wrestleu's Avatar
my kit came with 3 gaskets. 2 of which were almost identical with the exception of the cam chain area. the third gasket has metal ring and the gasket material around it. i know where that one went, however the other two I believe I got them reversed...so I'm assuming I would lose compression where the notch out for the cam chain gasket.
Old Oct 11, 2005 | 04:05 PM
The base gasket has nothing to do with compression.......it will just leak oil if it doesnt fit correct
Old Oct 11, 2005 | 04:07 PM
You are talking about #2 in This Picture correct?
Old Oct 11, 2005 | 04:14 PM
wrestleu's Avatar
yes, except I put that gasket at the top valve cover and the other at the bottom....so there is a notch in the full circle. Should I tear it back down and redo it?
Old Oct 11, 2005 | 04:22 PM
I am still a little confused, but if you know for a fact that you installed the wrong gasket.........do it right...........little hint for you........when you reinstall the head gasket...use Copper-Coat on it ( get it at any parts store for a couple bucks). It will help seal the head gasket.
Old Oct 11, 2005 | 10:23 PM
wrestleu's Avatar
on both sides of the gasket i assume? thanks for the tip....will pick some up tommorrow for the weekend tear down and rebuild.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
