2001 AC 500 Man. backfires
Old Oct 16, 2005 | 11:43 AM
OntarioHunter's Avatar
Default 2001 AC 500 Man. backfires
Has anyone else had this problem, and what is the fix? Thanks
Old Oct 16, 2005 | 01:29 PM
hondabuster's Avatar
When does it backfire? On sudden throttle closing? When going on the gas?
Backfire is a sign of lean carb circuits or bad timing. If the motor hasnt been apart, then we can assume its carb related.
If it happens on sudden throttle let off, its the classic sign of a lean idle circuit.To verify that its lean...try pulling on the choke just before the throttle let off, and youll notice the backfire disapears.
Look for intake and exhaust leaks, and if you find none, ...turn the mixture screw about 1/4 turn richer, this will enrichen only the idle circuit., which is what it needs.
Old Oct 16, 2005 | 02:41 PM
Thanks a bunch- I will try...
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Brandon400
Sep 7, 2015 12:20 PM
