lowering ride height?
Old Oct 16, 2005 | 07:28 PM
cr125predator's Avatar
Default lowering ride height?
I recently bought CFM lowering blocks for the front only. Since it rides in an angle i would like to lower the back end. Is that possible, and if so would it be hard to do. I dont want to lower it very much. Any info is great
Old Oct 17, 2005 | 02:07 PM
heatseeker8's Avatar
dont know how we missed this one off the front page...but sure you can lower your rear ride height....by tighten your compression spring in the rear...you may, like I did, wind up with some bloddy knuckles after its done...but it will work a little..expect I stiffer ride for sure...however I can hit our woops a tick faster.
Do those lowering blocks put a strain on the ball joints at all?..I got my preload set at zero and when I lift the suspesion complelty off the ground i hear my springs seperate from the shock..I got it as low as I'm comfortable with in the front...
Ean
Dec 19, 2022 08:48 AM
Frisky2050
Apr 9, 2020 11:19 AM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
