Team clutch????
Old Oct 15, 2005 | 08:45 PM
wildwilly's Avatar
Default Team clutch????
I put a set of 27" gators on my 2006 800 efi today and took the belt cover off to change springs and weights ,i noticed that the belt was 1/4" above the team secondary .just wondering if this is normal?or do i have to shim the clutch and how do i do it? thanks william
Old Oct 15, 2005 | 08:46 PM
baxy's Avatar
probably makes for awesome bottom end!!!
I would leave it unless your quad creeps when idling in gear or it is hard to shift between ranges
Old Oct 15, 2005 | 08:56 PM
wildwilly's Avatar
it's not creeping or hard to shift so i will leave it we have atv pulls next weekend .thanks for the reply william .
Old Oct 17, 2005 | 10:06 AM
scramblered's Avatar
i'm wondering why are you so upset with the team clutch,
the only gains you'll have is smoother,cooler running secondary
and a little better low end response.
i've seen some very disapointed top end lost with a roller,the clutch seem to always over shift at top end cauze of the rolling inertia
it produce at high speed,i've been tuning the stock clutch for
some years now,and NO team clutch can match the effiency of my present
setup with HPD helix and some others tricks.
1/4 on top of secondary seem about right tough,if you want more top
just remove shim inside to drop the belt from the top of the clutch.
Old Oct 17, 2005 | 10:43 AM
Speedwerx's Avatar
If it's not creeping or squeeling you are fine the tighter the belt hte better on the ebs models.
Old Oct 17, 2005 | 02:49 PM
modquad's Avatar
Team Industries buyers guide:
1) Purchase the Team Clutch.
2) Install the clutch.
3) Squeeze the throttle.
4) Grin
5) Don't stop grinnin'. [img]i/expressions/face-icon-small-smile.gif[/img]
One of THE best mods for your Polaris ATV!
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
