DS rough running ?
Old Oct 16, 2005 | 07:59 PM
Bone1208's Avatar
Default DS rough running ?
DS is running rough around 2000 to 3000 rpm. Sounds like it is coughing through the carb. It runs strong above 3000 rpms. could this be a jetting issue or a cdi issue. Thanks for any help.
Old Oct 17, 2005 | 01:26 AM
Oldmanracing's Avatar
You have to adjust you jetting when you run the Big Gun CDI.
If you have a jet kit, read the instructions. If they say the needle is to be set in the 2nd groove, you should raise the needle one more. 3rd down from top.
Pull out your needle and see where it is. Then raise it one more.
SOLOLUCKY
Oct 4, 2024 09:09 PM
wannabe32
Jul 7, 2015 11:30 AM
gfl0224
Jun 27, 2015 06:52 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
