Relocation of Rectifier after ditching the airbox
Old Oct 17, 2005 | 03:19 PM
Entomber's Avatar
Default Relocation of Rectifier after ditching the airbox
Question for all you guys who ditched the airbox and still run the large air tube, where did you relocate that rectifier? I need some ideas.
Old Oct 17, 2005 | 03:25 PM
JMAC650's Avatar
I bought a 1" strip of alum and put 2 90 degree bends in it on each end and mounted it between the frame on the front rear bumper bolts. If you have an email I will send you a picture. It is very simple and looks very clean.
JMAC650's Avatar
Also made a custom bracket to hold the air tube and breather tube, looks clean as well.
Old Oct 17, 2005 | 04:11 PM
thebigshow's Avatar
i just bolted it to th frame nright above the rear shock...the bolt pattern matches up and its out of the way...
Old Oct 17, 2005 | 04:12 PM
biggerisbetter's Avatar
Their is just enough room to mount the rectifier on the underneath of the rear plastic. the part that houses the tools and manual.
bigger.
Old Oct 17, 2005 | 05:28 PM
VEGAS650's Avatar
I have it on the side of the subframe, near the battery.
One bolt in one of the holes and a zip tie through the other hole.
Joe454
Nov 20, 2020 01:19 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
