are there any fuel additives to...
Old Oct 22, 2005 | 11:07 PM
ZimRaptor's Avatar
Default are there any fuel additives to...
clean the carbs?
if so do they work well? every now and then the *EDIT* wont start, take out the plug and its fouled......
do u guys think the carbs are dirty or i need a new filter?, made no difference when i clean the filter but its stained pretty badly
Old Oct 22, 2005 | 11:19 PM
Doctorturbo's Avatar
GOT BOOST!
Your fouling a plug on a four stroke? You super rich. Jet the main jet down.
Old Oct 24, 2005 | 09:04 PM
ZimRaptor's Avatar
yea im afraid of melting the piston...what do u think i should do? i dont wanna tear the carbs apart, should i get the dealer to do it i dont mind spending a hundred bucks or so, as long as im guaranteed it works
Old Oct 24, 2005 | 09:09 PM
3wheelerdude's Avatar
Just put a smaller main jet and then plug chop it again. REad your plug and change the main jet again if needed.
Old Oct 24, 2005 | 11:10 PM
recon99's Avatar
if you're not sure what you're doing then just take it to a repair shop and let a pro do it. If a 4 stroke is fouling plugs something definitely isn't right.
Old Oct 25, 2005 | 08:44 AM
vdubspeed's Avatar
if it's running rich and fouling plugs then why do you think it's going to melt a piston
[img]i/expressions/face-icon-small-confused.gif[/img]
you would have to be pretty lean and hear some knocking/pinging/detonating before you start hurting a piston.
Old Oct 27, 2005 | 08:11 AM
ZimRaptor's Avatar
because my friend did it with his waverunner
Old Oct 27, 2005 | 08:36 AM
maddog56's Avatar
Rich doesnt burn up pistons, you're plug will foul and the bike will quit before any major damage is done. Lean is what kills. Somehow I'm guessing your buddy's waverunner wasnt a four stroke running rich, or if it was then it had other reasons for going south.
Your bike looks stock from your signature, the jetting should still be stock if you havent messed with it, and without any modifications I dont see why you would. I'll bet your choke is stuck on or a float is stuck.
Old Oct 28, 2005 | 12:07 AM
ZimRaptor's Avatar
i know the stock design crap filtration system has been letting a lot of dirt get by....but besides that it idles somewhat rough at times, and other times just fine....i never have a problem taking it through the powerband ie. no backfires, sputters etc.
Old Oct 28, 2005 | 12:28 AM
GOT BOOST!
Do a compression test.
