oil coming out of the crank case breather???!!!
Old Oct 23, 2005 | 12:43 AM
budtbaar's Avatar
Default oil coming out of the crank case breather???!!!
I need your'alls help!!!
went for a ride today, cool right?!!?? Got off my bike for a break and the back was full of oil FULL ! ??!!!
Dripping out of the crank case breather?!! The oil was a milky white, but still oil,, not good!!? Checked oil level . Just a 1/8" reading on the dip stick.
It was between the two notches when I left. Drained the oil looks NORMAL? I HAVE A OIL PRESSURE GAUGE THAT WAS 35LBS. AT IDLE TO 60 LBS RUNNING
WHAT THE F^% k??? ANY iDEAS??? HELP!!! LOL thanks Bud
Old Oct 23, 2005 | 12:51 AM
Scatterbrain's Avatar
PM Donal, He has the same problem. I cant remember exactly but I think it has somthin to do with the oil pump. He was having the same problem and had to replace one of them (I think theres 2) If you cant reach him call kelly he figured it out for Don.
Old Oct 23, 2005 | 01:05 AM
budtbaar's Avatar
This happened to me once before. Talked to kelly bout it. When I put in a new clutch I checked the pumps TOOK BOTH APART LOOKED FINE!? I thought I just over filled the tank. It stopped when the oil level got to the bottom of the dip stick. Could the pump be freezing up intermittinly(spelling)? Checked the filter, found a fair amount of metal shavings looked like copper AND silver in color?? not good!
tx
Old Oct 23, 2005 | 01:31 AM
Sparky8370's Avatar
Do these quads have PCV valves? Milky white oil, sounds like your getting water (possibly cooling system) or high air pressure, maybe blowby.
PCV stands for positive crankcase ventilation. I know mine has one. If these go bad, they'll build up pressure in the crankcase. Are you burning any oil?
Old Oct 23, 2005 | 01:37 AM
crackerJack's Avatar
Water pump seal probably went on ya. Was it milky on the dipstick or when you drained the oil you saw it in it. When I would run methanol I would get a little milky oil or condensation on the dipstick but you could not see it when you drained the oil. If you have enough to see it in the oil then you are looking at a pump seal or worse, gasket leaking.
Old Oct 23, 2005 | 01:59 AM
budtbaar's Avatar
Don"t think its burning oil?? did it once before,,, then didn't for a ride ,,, then did it today???
Old Oct 23, 2005 | 02:00 AM
budtbaar's Avatar
Justin check your pm Bud
Captjay
Jul 23, 2015 12:33 PM
toonces
Jul 21, 2015 02:40 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
