Engine noise on new moter?
Old Oct 28, 2000 | 09:13 PM
Dazed's Avatar
Ok it is a 99 400 scram with a new moter head and cylinder the works it is all stock except a K&N filter running a 230 main. It has a sound like detenation, When just cruising along when you gas it it goes away also kinda sounds like piston slap. Now remember this moter is new from the base gasket up and was rebuilt be the dealer under warenty. What could could the noise be caused by or is it needeng more break in time this just dosent sound right. Could it be the carb air screw need adjusting? Air temp is a balmy 41 degrees out. Also the noise is just after you get into the pipe and alittle past. Whats the deal with this.
Old Oct 28, 2000 | 09:55 PM
PolarisMan's Avatar
Look below
PolarisMan's Avatar
230 main jet? Isnt that a little heavy? But as for the probablem i have no clue, I would look in the ignition timing or spark plug maybe. Or maybe tighten cams, if app.
Old Oct 28, 2000 | 10:15 PM
Dazed's Avatar
Actually no 230 is stock from 40 to 80 degrees but i am draining the tank now and will fill it with 92 octane see if that helps maybe it like more octane now and will rais the jet to a 250 As it is colder out now. Any more idais will be helpfull.Thanks
Old Oct 29, 2000 | 09:50 PM
Dazed's Avatar
Come on guys where are the Gods ? Chopper bill rick anyone!!!!!!!!!
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
