The News on my 450r
Old Oct 26, 2005 | 03:13 PM
TL450R's Avatar
Default The News on my 450r
well a while ago i posted telling everyone how my 05 450r blew up on me. what happened was the oil leaked out of the drain plug which vibrated loose. after the oil leaked out, my cam chain guide and tensioner melted, causing plastic to be spread throughout the top end. when i kicked it to start it, the cam chain fell off the sprocket the intake valves dropped, and the piston hit them. the cylinder is ok, but i am getting the athena 480 kit, stainless intake and exhaust valves, and the rest of the parts to fix it. i know reconranger wanted to know what happened and for all else, make sure you have oil in the tank before you ride!!
Old Oct 26, 2005 | 05:53 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
So are you sure the bottom end of the engine is ok?
Old Oct 27, 2005 | 02:40 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Bottom end should be OK because it has its own seperate oil supply (just like a 2-stroke).
This is interesting to me, because mine came from the factory with a leaking drain plug. When I first got it, there was a puddle of oil on the garage floor every morning. The bolt was tight, so I just let it go until my first oil change. After taking the plug out and putting it back in, it has been fine.
Old Oct 31, 2005 | 09:36 AM
TL450R's Avatar
i am pretty sure the bottom end is ok, just kinda worried about the crank sprocket. if that is bad i need a whole new crank. but hopefully it is ok. my mechanic is looking at the bottom end today. he says it should be fine because the sprocket on the cam was fine. lets keep our fingers crossed though.
Old Nov 1, 2005 | 01:04 AM
Jumbo747's Avatar
sounds like you should be safe and get a whole nother engine then mod this one and have something creep back up in a few days of riding
Old Nov 2, 2005 | 10:16 AM
TL450R's Avatar
yeah well if you can just give me the money to do that, i will be more than happy to consider that option, but seeing as i dont have a few grand just waiting to be spent, ill just hop up the engine i have.
Asaran
Oct 8, 2015 11:14 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
Aug 18, 2015 01:00 AM
Aug 5, 2015 02:10 AM
