Raptor shifting issues
Old Oct 26, 2005 | 04:04 PM
prostitute7's Avatar
Default Raptor shifting issues
I have a 2002 Raptor 660. I've been having problems shifting from 2nd gear to first gear. It happens even when sitting still. It goes into neutral fine, but won't shift on down to 1st about half of the time. Sometimes, I have to get off of the bike and pull the lever up and down by hand to get it into first. I switched to an IMS direct shifter now, and the problem is still there. Any ideas? Thanks.
Old Oct 26, 2005 | 05:23 PM
maddog56's Avatar
Make sure your clutch is well adjusted and not engaged or applying pressure when it shouldnt be.
Old Oct 27, 2005 | 12:02 AM
Raptorflash1's Avatar
make sure your clutch cable is adjutsted properly and make sure the lever is not hitting something. When I changed my lever I had it one tooth off. Made the reach to 1st gear much better but couldnt make it into 5th.
Old Oct 27, 2005 | 12:19 AM
UBETRUN's Avatar
If you have the stock sprocket guard, you'll probably have to trim off the bottom corner for clearance. It's only plastic, easy to trim.
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
