valve cover assembly?
Old Oct 29, 2005 | 08:29 PM
wrestleu's Avatar
Default valve cover assembly?
Does the valve cover get a gasket? I bought an upper gasket kit and didn't get a gasket that will fit it, so I'm assuming it does not. I may just try some red rtv. I may not be calling it the right name, it's the very top cover on the engine, where the rockers are and the valve adjustment caps are. Anyhow, for some reason the kit didn't have a gasket for that so I'm gonna assume it doesn't need one since it is a dry compartment anyhow.
Old Oct 29, 2005 | 11:42 PM
thebutelr's Avatar
The valve cover does not use a gasket, you have to buy some gasket maker and apply it yourself. A small paint brush works wonders for applying an even coat around the head.
Old Dec 5, 2005 | 10:16 PM
lawnboymelvin's Avatar
hi do not put a gasket on it the valve cover does not take a gasket because there is no oil splashing in it so no liguids will leak out
Cole Hadden
Jun 15, 2025 09:05 AM
rawbdiggity
34
Sep 2, 2015 02:16 AM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Aitch
Jul 21, 2015 09:40 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
