Need help on couple things..Please read
Old Oct 29, 2000 | 09:43 AM
IAJack's Avatar
Hey all,
I have a 2001 scrambler 50 for my son, it is only a couple months old. It seems to be very hard starting everyonce and awhile, I believe it is beacuse of the automatic choke on it. It seems to flood really easy? Any ideas or is there any adjustment to the auto choke on these?
Other thing, can I or should I run octane booster in my Trailblazer? does anyone do this and does it help any or just hinder? will it hurt?
Lastly, chain lube, is lube containing Moly OK?
or a penatrating type, or should I just stick to one that says it is for sealed rings and not worry?
Thanks all
IAJack
Old Oct 29, 2000 | 01:20 PM
Lurch77's Avatar
Can't answer the first question, but I can the other two.
Octane booster will not be of any help to the TB. Higher octane fuel is used primarily to keep high compression engines from knocking and dieseling. The TB has a compression ratio only in the 6's. Can't remember the exact number, but its around 6.5:1 or so. Regular pump gas is more then enough for it.
Any quality chain lube that specifies it can be used for o-ring chains is all you need for the chain. Some people prefer to "wash the chain with a penetrating oil like wd-40 before adding the o-ring chain lube. But what ever you do, use a lube made for o-ring chains. This will keep the o-rings soft and working the way they should.
Old Oct 30, 2000 | 05:29 AM
EXPLORERATVER's Avatar
LURCH77 YOU SAID SOME GUYS USE WD40 TO CLEAN THEIR CHAINS,THAT WON'T HURT THE O-RINGS? WHAT ABOUT ENGINE AND TIRE WASH AT A CAR WASH? THANKS IN ADVANCE.
98 XPLORER 300 4X4
Old Oct 30, 2000 | 10:41 AM
DieselPro's Avatar
Hmmmm, Bonduel WI
Did R&S take on the Polaris ATV line as well as sleds over there?
Any good mudding over there?
Old Oct 30, 2000 | 12:45 PM
Lurch77's Avatar
EXPLOEREATV, I emailed you your answer.
And for the record, I am militry stationed in Maine, but am from Oconto WI, just north of Green Bay.
Old Oct 30, 2000 | 04:35 PM
Thor's Avatar
Oh, O, OOOOconto Beer!
Old Oct 30, 2000 | 11:04 PM
Lurch77's Avatar
Wow, what a shock to see someone else, especially not from WI, that knows about Oconto beer! How do you know about it? They sell it out there? Most people that know about it only live in Oconto.
2quiker
Mar 22, 2022 08:36 PM
atvcollector
Sep 8, 2015 05:11 PM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Sep 8, 2015 10:51 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
