k&n oil on foam filter
Old Oct 31, 2005 | 12:03 AM
BoomSling's Avatar
Default k&n oil on foam filter
Will my stock foam filter get messed up if i put K&N filter oil on it? Just wondering.
Old Oct 31, 2005 | 12:51 AM
hondabuster's Avatar
You could probably get away with it for awhile, but eventually the solvents and dispersants in the KN oil will eat the foam. The KN oil is designed to work with the cotton fibers in their filters, not with foam. The foam air filter oil is cheap, and one small bottle can do at least 5 filters.
Old Oct 31, 2005 | 10:42 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I used it for a while on a UNI filter and it kept any dirt from getting thru, but I cleaned and re-oiled it often. I would recommend using a foam-filter specific oil tho, it does protect your engine better.
Old Oct 31, 2005 | 09:24 PM
BoomSling's Avatar
thanks ya'll for the replies. i put k&n oil on my filter because that's all i had. I'll get some foam oil from now on.
andy
Old Nov 1, 2005 | 07:36 PM
BigRanger's Avatar
I may be a dumbass for doing this but will it hurt to use engine oil on an air filter if there is nothing else.
Old Nov 1, 2005 | 07:47 PM
No, youre not a dumbazz, if you ran it with out any oil, that would be dumb.
The foam is only designed to hold the oil, and the oil holds the dirt.
In a pinch, any oil, (even cooking oil) is better than dry foam. motor oil will end up dripping off, and leaving the filter dry, so when its posible, wash it clean and put the right stuff on. Any product which says foam filter oil, is the right stuff.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
mbriggs
Sep 13, 2015 10:47 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
