14" Tires and Rims
Old Oct 31, 2005 | 10:36 AM
BOAGIE's Avatar
Default 14" Tires and Rims
Any thoughts or experience with this set-up? Just wondering if it's worth the $800.00 price tag.
Any real world benefits or more of an EYE CANDY, kinda thing?
Thanks Marc
Old Oct 31, 2005 | 10:39 AM
BOAGIE's Avatar
Meant to add, this was about the I.T.P. Type 7 Rims, 14" diameter as opposed to the standard 12".
Old Nov 1, 2005 | 04:13 AM
jimmypsp700's Avatar
You get a very aggressive tread and good ground clearance while retaining a shorter sidewall for sport riding.
Jim
Old Nov 1, 2005 | 04:48 AM
Starky's Avatar
You get a shorter stiffer sidewall. Easier to slide around corners. Maybe a little less probability of a side wall puncture. Personnaly, I don't think it's worth the money unless you just want to be a little different than everybody else.
Old Nov 3, 2005 | 03:30 AM
See here...http://photobucket.com/albums/y148/j...%20ORV%20park/
they look real nice and have a very aggressive tread design.
Jim
Old Nov 22, 2005 | 08:55 PM
lafngas's Avatar
I just put the 12 inch version of the itp mud lite radial and didn't see much difference between the mud lite and the mud lite radial the radial rides a bit smoother and grips the rocks and roots better but I don't think they were worth the extra cost over the mud lites. Good Luck
Old Nov 22, 2005 | 09:29 PM
Daranello75's Avatar
Originally posted by: jimmypsp700
See here...http://photobucket.com/albums/y148/j...%20ORV%20park/they look real nice and have a very aggressive tread design.Jim
WoW, that BomB 800 looks amazing with the 14"
Old Nov 26, 2005 | 02:14 PM
24houradrenaline's Avatar
Its all just personal pref but i think that the 14inch rims make the quad look more tough, also if you use it on road more than off road than it would be easier to find car tires to fit the 14inch rims rather than the 12inch rims.just some food for thought.
Old Nov 26, 2005 | 02:38 PM
2TV's Avatar
2TV
Personally for off road riding I’d prefer a smaller wheel since the tire also plays a significant part in the shock absorption process. If you were confining yourself to dirt trails / tracks or other similar smooth surfaces then a larger wheel / smaller profile tire combination will improve your handling by reducing the amount of tire sidewall flex.
However if you are riding in the woods or where you would otherwise find lots of rock and tend to be an aggressive rider, the smaller wheel / higher tire profile combination will reduce the amount of shock that is transmitted to the machine and to you. It should also reduce the chance of getting wheel damage caused by rock impacts...
Old Nov 28, 2005 | 04:38 PM
skidoog's Avatar
They look extremely awesome! Other than that, the benefits are small.
