Need advice on tough banshee pipes
OK.
I'll need some experience from the guys that ride hard caus I'm tired of breaking my pipes or pipes barckets on my 98 banshee.
I broke the first bracket of the silencer for the stock pipes (the first bracket is the one hidden behind the plastic) on both sides.
So I changed my pipes (I already had them... didn't buy them because I broke a bracket), and put on the noisy ones. We went riding today, found a real nice jumping place...not very far, but quite high (my pal told me 6-7 feet high)..landing was a bit tough...bottoming hard each time, even in the slight downhill, ad I broke the silencer of my "whatsoever" pipes. I just broke, bing. I toughed for 8 jumps before breaking.
So here's my question. What are the toughest pipes for a banshee? I'm p**** off at breaking my pipes each ride...and it's just gonna be worse and worse because I'm still learning how to ride this machine (and man do I love it!!!!!!), riding each time faster, harder...
So, from the MX experience you guys have (or tough riding), what are the best pipes (tough, powerful, spark arrested, but that sound good)?
Thanks
Thanks
Was it the actual bracket for eh pipes, or the rubber between the 2 metal peices? If it isjust the rubber, put a botl through the hole and call it good. Ive never seen pipes break in other places..
RoostKing...
RoostKing...
I think you mistyped...you want me to teach you how to ride...right? If you can keep the pace, watch and learn, pupil!
Nonononono.
hem. Well. I'm gonna name all the brackets from the cyl to the end, and tell you which one are broken.
the first things to hold the pipe are the springs, they're OK, then the big metal/rubber brackets, then switch from pipe to silencer (with that little transition part for stock pipes), then the brackets on the frame (it's part of the frame, they're hidden by the plastic) these are broken, then the next ones, the thread is f****, and the final ones are more or less OK.
However, I'll reinforce the broken ones, put helicoils where the tread is out of order, and I hoe it'll be OK.
Ahhh come on I smoked a Polarass Scrambut 400 all hyped up by HPD on a nice logging road. And even BETTER I have to do my top end because of low compression. So just watch my dually exhaust Scrambut AND JUST DREAM OF THE SPEED OF THE BANSHEE Plus I have yet seen a Scrambut Jump over a foot off the ground 550 Pounder and watch your trainy don't crack it when going threw some Mud
