jetting for a uni on Viper 90
Old Nov 7, 2005 | 01:08 AM
Knowpig's Avatar
Default jetting for a uni on Viper 90
I am thinking I may ditch the stock filter and put on a Uni on my little guys stock Viper 90.
It runs a Mikuni 18mm carb with an 85 main jet.
Anyone have any idea what main jet I should run with a Uni?????
Old Nov 7, 2005 | 09:56 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
I would make sure the needle is adjustable before you try. Then I'd guess 95-105.
Old Nov 7, 2005 | 02:37 PM
Fastestdad's Avatar
My guess 149 mainjet. My recommendation - dont do it stock carbs are a pain to jet with podfilters, as they need good airflow to suck up fuel thru mainjet. Usually doesnt run right for long. Sorry just my $.02
Old Nov 7, 2005 | 05:28 PM
Knowpig's Avatar
I have another one that I run a Uni, 54mm cyl, and a Hetrick pipe. I run a 125 main jet and it's been trouble free for a year.
Maybe the Mikuni 18's are not as big a pain as the 16's???
Old Nov 7, 2005 | 05:37 PM
LT80's Avatar
LT80 Expert
There could be variables, but a stock motor shouldn't require much of a jet change if any.
Let the plug color guide you (as allways).[img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 7, 2005 | 05:40 PM
Raptorlegs's Avatar
T Rex Rider
Fastestdad is right about people having trouble with some of the stockers but I would think the 18mm would be easier. Also, you can buy a universal vent filter if interested. I think you could go with a small one and be just fine but I haven't tested this theory. Smaller surface area, less air gets in......is my "theory" anyway. Right or wrong. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 7, 2005 | 06:52 PM
oldyeller's Avatar
Don't know what jet size you would need but just thought I'd add that the needle is adjustable on our 04 viper.
Old Nov 7, 2005 | 10:35 PM
Trasher's Avatar
Do you think changing the filter to a Uni would even do enough to notice? I have been kicking around doing that also.
Wasn't looking to put a pipe on it at this time.
Old Nov 8, 2005 | 11:24 PM
Knowpig's Avatar
It's not so much the quest for power on this particular unit. If you have ever looked inside the stock filter on an e-Ton Viper, then you know it leaves much to be desired in terms of good filtering. I think the Uni will protect me a bit more, and ad a side effect I MAY get a bit more power. But the power is not the issue here, it's the filtering.
Old Nov 9, 2005 | 03:14 AM
Randes's Avatar
I just pust a UNI filter on my son's Viper 70 and I had to use a 100 jet and adjust the mixture screw.
