I'm back
Old Nov 7, 2005 | 02:30 PM
sportsman2004's Avatar
Default I'm back
Hello all, it has been a while. I recently moved and long story short just have not had time to write. I have a couple of questions.
I was stripping down my 700EFI doing maintanence to it and found a red vacum line with a vac canister on the end of it. I can not see where this goes. Any ideas?? Also, why does it seem like more fluid came out of the front/rear differential then what I can get in?
Also, I am looking for some ideas on clutch work. I have a kit in it (can not remember where I got it), it has the adjustable weights on it. I have recently taken off my Extecutioner rims and tires and went to ITP Spider Trac tires. I beleive they are 26" on the back. Any ideas on what I can do? The quad has just fallen on its face since I put these tires on. Looking for ideas.
Does anyone have the link for hooking all three lights up?
Old Nov 7, 2005 | 08:37 PM
Jayblazer's Avatar
Default I'm back
what name did you use to post under??
Old Nov 7, 2005 | 08:53 PM
SPORTSMAN70003's Avatar
Default I'm back
I can help you out alittle on the clutching. Sounds like you already have the heelclicer clutch kit. I would recommend getting a 800 primary and put the heelclicker clutch kit in it that will give you alot more low end. I also gain 3 mph on top speed.
Old Nov 8, 2005 | 01:32 AM
tyler711's Avatar
Default I'm back
Wait, are your front and rear tires different sizes? Or is that just the measurement you remembered. Different sizes is not a good thing.
And for the three light mod, just do a search, you'll get a lot of hits with the links to the packages and the DIY instructions.
Old Nov 8, 2005 | 03:38 AM
UTU's Avatar
UTU
Default I'm back
Got mine off e-bay for $5.75 including shipping. Just search Polaris lights easy enuff to install too!
Old Nov 8, 2005 | 03:41 AM
Default I'm back
Thanks Sportsman70003. Glad to see you still hit everyone of my posts. So, do you know what that red vacum line about 3" long with a lit vac booster on the end goes to? I have read alot about the 800 primary. It is not a heelclicker, it is BMP Supertip clutch Kit from Bikeman performance. Took me a while to remeber it.
Your front spring spacers, do you make those? I am interested....
On your 800 header install, is it worth it? I have EFI, so will this affect anything. I have already purchased the 800 snorkle, but have yet to install it.
Do you have a thread for the Headlight MOD?
Thanks
Old Nov 8, 2005 | 03:44 AM
Default I'm back
sportsman04...I could not remeber my password so i had to set up a new account. I got a new computer after I moved, so I lost mostly everything...
Old Nov 8, 2005 | 03:51 AM
UTU's Avatar
UTU
Default I'm back
Light kit on e-bay here is a link. Got mine has great instructions easy to install.
http://cgi.ebay.com/ebaymotors/Polar...88239079QQrdZ1
Old Nov 8, 2005 | 09:29 AM
Default I'm back
Thanks
I'm not for sure where the vacuum line goes on the EFI sorry. Yea I made the spring spacers from some metal conduit cut 1" thick. The 800 header I gained some low end I'm not for sure how good it would do on a EFI. I have heard some people gained and some people didn't with the 800 header. I had the directions for the headlight mod but I lost them somewhere I will try to find them some time today.
Old Nov 8, 2005 | 02:36 PM
Default I'm back
Thanks Sportsman70003. How hard is it to install the spring spacers? What size conduit did you use?
Does anyone know where this vacum line goes? I found it lying on top of my starter when I was cleaning my quad. I can not see where it goes with out removing everything. Any ideas? Anyone?
Also, do you need a needle tip for greasing up everything? I only have 2 grease zerts and they are for the ball joints ...
