Predator HMF
Old Nov 8, 2005 | 09:29 PM
Defkon77's Avatar
Default Predator HMF
Just installed HMF pipe and header on my 05 TLD........I am using the stock airbox with K&N drop in.....and yes I understand not getting the full performance out of the pipe with the stock airbox and lid...LOL......pilot jet is one size up HMF gave me a 155 main.......runs great alll across the board...no stumbles....dead spots...etc.....just curious if 155 is enough....should i go higher?....also the header seems a little close to the oil tank...don't remember how the stock one looked...anyway thanks for your input.....
Old Nov 8, 2005 | 09:38 PM
Bradracer18's Avatar
header/oil tank will be fine.......
Yeah......that seems like it might be kinda lean......but I don't know where you live(altitude and temp)........
I'd run it hard......shut it off(no idle)......and then check the plug......
My guess is it needs to be around 160
Old Nov 8, 2005 | 10:15 PM
Defkon77's Avatar
160 seems to be the common answer i get.......thanks alot for the input......still learning about quads and carbs....i work as a gm tech......i can't set up my jetting but dammit i can fix your OnStar!!!!!!!!!LOL.
Old Nov 8, 2005 | 10:35 PM
spyder6's Avatar
congrats on your TLD, if you can, take a look at a Rath Raceing Stainless Steel head pipe, the best made and the best performance, and it will match up beautifully with that HMF pipe. its about 200 bucks, im sure you can sell your HMF header for a nice lump, even if it is a little bit of a loss.
www.rathraceing.com
btw, when i get some dough, im putting the rath on
Old Nov 8, 2005 | 10:38 PM
I would not reccomend the rath headpipe if you already have the hmf full system(headpipe and exhaust)......The rath won't give you much above what you already have.
My next investment would be the Nicholas cycle carb mods, and a clamp on air filter......
www.nicholascycle.com
Old Nov 9, 2005 | 06:46 PM
spyder6's Avatar
you and those carb mods...
Old Nov 9, 2005 | 07:53 PM
trailrider500's Avatar
I'm running a 175 main with my HMF carb mod and clamp on, i think i ran a 160 or 165 MJ when i just had the system.
TR
Old Nov 9, 2005 | 08:17 PM
spyder........don't bash the carb mod, when you don't even know anything about it........ok?
Looks like TR^^^ also has it done........
Old Nov 9, 2005 | 08:46 PM
cr125predator's Avatar
what would modding the carb help with. This might sound like a dumb question but i have no clue why it would give you more power.
Old Nov 9, 2005 | 08:47 PM
Oh, and are all these different people mix matching the slip ons with different head pipes. arnt the full systems tuned for each other, so would it work better?
