AIR MIXTURE - PRED 500
Old Nov 9, 2005 | 06:56 PM
TNTINSURANCE's Avatar
Default AIR MIXTURE - PRED 500
I am setting up my carb for a new pipe I just got. The pipe mfg says the air mixture screw should be at 3 turns out. Problem is I cant seem to locate the screw. I thought it was on the outside of the carb. I already changed the jets and needle clip to their specs, just need to figure this part out.
Where is the air / mix screw?
Thanks,
Walt
Old Nov 9, 2005 | 07:56 PM
XShowtimeX's Avatar
It's on the bottom of the carb in the front, you have to remove the brass welsh plug first to get at it. Stock from the factory I believe it's turned out 21/2 turns.
Old Nov 9, 2005 | 08:31 PM
Found the plug. Do I have to drill it out?
Thanks,
Walt
Old Nov 9, 2005 | 08:38 PM
hak231's Avatar
Yes you can drill it out or youcan grind off about 1/4 inch and the plug pops out.
BYC
Sep 25, 2015 02:10 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
