2000 sportsman 500/cooling
Old Nov 11, 2005 | 06:37 PM
Spears's Avatar
Default 2000 sportsman 500/cooling
Hey folks! I have a 2000 sportsman 500 RSE that I bought as a repo. I'm slowly working on some of the problems.
The first one is that it has a coolant leak on the bottom of the engine. There appears to be some type of drain hole(?)below the water pump in the block. The coolant is leaking from there. I have removed the impeller cover and everything appears to be ok there. The engine must come out to service the water pump. Any body have any ideas? Thanks
Old Nov 11, 2005 | 10:13 PM
upnort's Avatar
Sounds like the seal in the water pump is leaking. Click link for a parts breakdown of the water pump. Had it happen to my 02
http://www.partsland.com/index.cgi?N...MAN-WATER-PUMP
Old Nov 11, 2005 | 10:30 PM
Spears's Avatar
Thanks for the link. I hate to sound dumb, but which seal is it? The schematic you sent shows the outer cover of the water pump impeller, but I think the actual water pump is inside the case?
Old Nov 11, 2005 | 11:41 PM
upnort's Avatar
#12. Your leak is out of the "weep hole" under side of the cover I take it. Dealer actually did mine.
The impeller #11 is actually the object that pumps the water. Kinda like a water fan.
Old Nov 11, 2005 | 11:45 PM
Spears's Avatar
Yep, that's where it is leaking from. According to a parts manual I printed off, it most likely is the "mechanical seal" and that is where the enging has to come out to crack the crankcase open to get it changed out. Do you mind me asking how much the dealer charged you for yours? I'm still thinking about attempting it myself.
Old Nov 11, 2005 | 11:54 PM
SportsmanEE's Avatar
Upnort is correct. Your problem is the mechanical water pump seal. It's a pretty cheap and easy fix. If you plan on changing it yourself, I would highly recommend that you either borrow or rent the required seal puller from your dealer. I'm sure at least 100 people in this forum will tell you it can be done without the puller, and they're correct. However, not being familiar with the process, you risk bending the water pump shaft, which the only way to replace is to crack the crankcase open. With the puller, the entire job should only take about 15 minutes and is easy enough for my wife to do.... [img]i/expressions/face-icon-small-wink.gif[/img]
Good luck.
Old Nov 12, 2005 | 12:06 AM
upnort's Avatar
Was like 80$ to do including parts. I did not want to risk bending shaft because of above reason. The "tool" whatever it is was 70-ish. Could try doing a search in the Polaris thread to see if can find more on it as it has been a fairly common problem.
mtdewmn
Jan 19, 2017 12:13 PM
velcro7279
Aug 24, 2015 01:15 PM
Stirling
Aug 11, 2015 07:23 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
