Help!!! Rubicon will not move
Old Nov 13, 2005 | 03:49 PM
MudSlinger69's Avatar
Default Help!!! Rubicon will not move
I was going top speed on the road when I heard a sound(something like when you shift it from D to L while moving) I let off the gas then hit the gas again all it did was rev up rolled to a stop put in all the gears had nothing,4x4 nothing.D1, D2, ESP nothing What do you Think happened????????
I changed the oil It was nasty but not over due(no shavings)
Do you thank it could be electrical?
THIS SUCKS
Old Nov 13, 2005 | 04:24 PM
HR's Avatar
HR
That totaly sucks. i hope it's nothing major. i'm thinking about buying one and 03 though. is yours under warinty? did you get the extended one.?
i'm interested to see what it is and what it took to fix it.
good luck....
HR
Old Nov 14, 2005 | 02:59 PM
Anything anybody??????????????????????????????????????????? ?????????
Old Nov 14, 2005 | 03:05 PM
K2's Avatar
K2
This may not be helpful, but you mentioned, "I heard a sound (something like when you shift it from D to L while moving)". I don't recall exactly, but I thought you are not supposed to shift or change transmission selections while moving. Maybe that has something to do with it.
Old Nov 16, 2005 | 03:50 AM
rubiconrider101's Avatar
well the last is right DO NOT SHIFT WILE MOVING but if you didn't shift which i don't think you did, it maybe somthing to do with the swash plate in the tranny going out. or even though it's rare a gear could have split some where in the final drive, so either on of two thing has to happen, if your not already you need to become a very good patient mechanic and pull it apart or take it to a dealership. good luck.
Old Nov 16, 2005 | 04:13 AM
No don't shift while moving
But it was that type of noise
I dropped it off at the dealer today and the way he talked if it was the trany Honda would more than likely cover it(it's up to the rep) He said four new Honda bikes in 3yr helps a lot too.
So wait and see
Old Nov 16, 2005 | 11:34 AM
chicano's Avatar
O Boy sounds like what the guy told me his did before i bought it. Not a good story i just finished splitting the cases last night and took the hondamatic tranny apart and it was destroyed. Here goes $750.00 plus my time.
Old Nov 16, 2005 | 02:16 PM
JRM's Avatar
JRM
if i go over 60MPH on my rubicon it will set a trouble code and lock the quad into 3rd gear... and the D1 and D2 flashes. if that is your issue Its fixed by pulling the battery cable off for 5 minutes
Old Nov 16, 2005 | 03:05 PM
ridinhigh's Avatar
Thats weird, never heard that before.
Mudslinger that does really suck. I don't have many more than 200 miles on my 06 and haven't had no probs yet. Other than my stereo draining the battery. Its hard to tell what the prob could be. Don't have any experience on these quads yet. The trannys are so technical, but it could be something so minor as a spring. I'd really like to know the outcome though. I got the extended two year warranty, so I should be ok for a while.
Old Jan 29, 2006 | 04:11 PM
Well I broke the clutch hub after some sweet talk Honda covered parts so the price was $750 they dropped it to $306
NOT GOOD ENOUGH 4 Brand new bikes in two years ruby was only 2 mo. out of warranty
I think I'm going to but a outty 800 with the 5 year warranty
MAYBE king or brute ? ? ? ?
