Predator big bore question
Old Nov 23, 2005 | 02:36 AM
pleasure4qt's Avatar
Default Predator big bore question
12.5-1 Wiseco 5.63 mm over piston
Think thats the 558cc 104.84 bore piston
Can you just bore the stock cylinder?
Or do you have to re-sleeve it?
Old Nov 23, 2005 | 11:15 AM
spyder6's Avatar
HPD sells a 558 kit , you re-sleeve it
Old Nov 23, 2005 | 01:40 PM
How many cc's will the predetor have with the Wiseco 5.63 mm over piston? Is it 558 or is it something smaller?
Whats the largest bore you can go with the stock sleeve?
Thanks,
Old Nov 23, 2005 | 01:54 PM
spyder6's Avatar
i have no idea, i know though that you can get a 600cc bore kit from HotSeat
Old Nov 23, 2005 | 07:59 PM
Ok, I now know its 558cc
Will it be safe to just bore the cylinder?
Must I re-sleeve?
Whats is the biggest you can go without re-sleeving?
I have mine torn apart now cause of a broken piston at 20hrs on brand new 04 engine that Polaris gave me for my 03 TLD Pred. Yes, I never drive it.
14 hours was just sitting brake burning tapped out in 5th gear until it would get so hot it would quit. Then cool off and do it again. Yes, I'm amazed also it last that long seeing as it would be boiling fluid each time also.
I don't plan on doing this the second time around by the way. lol
thanks.
Adrian
Old Nov 23, 2005 | 09:52 PM
spyder6's Avatar
sounds like your running SUPER rich to have been overheating and cracked a piston. as far as i know, the only bore kits out right now you have to re-sleeve
Old Nov 23, 2005 | 10:04 PM
Quad is stock. I figured the reason it would burn out till it quit was because there was not enough air flowing through the rad with just the fan running and not any extra air from the bike actually moving.
Guess I'll either leave it stock or find a sleeve also.
Old Nov 23, 2005 | 11:07 PM
spyder6's Avatar
well if your just sitting there doing a burn out with your engine rev near maxed out then of course your going ot have cooling problems. but if your running it hard and fast then there shoudlent be a problem at all. the fan comes on alot because its set to come on at a lower tempature to keep the engine cool. i have no idea why your piston cracked though if thats it though
cornermike
Sep 10, 2015 08:30 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
bmark0610
Sep 7, 2015 09:42 PM
Elkaholic
Sep 6, 2015 02:44 PM
