New atc owner need help
Old Nov 27, 2005 | 08:12 PM
ratkiller's Avatar
Default New atc owner need help
I bought a 1984 atc 200M for 5 dollars. i am not sure of the engine condition other than the seller said it ran and it was parked and sat for almost two years before i purchased it. Downside it has NO key for the switch is there a way i can buypass this while i work on the trike? I have already changed oil and drained the tank what else should i do before i try to crank it? PLEASE HELP thanks
Old Nov 28, 2005 | 01:22 PM
3wheelerdude's Avatar
Take carb appart and clean it out. Change spark plug with new one. Clean air filter, check for mice nest!!!! OIL chain (if chain driven) change gear oil (if shaft driven) Get a new battery.... And yes you can bypass key switch. You can either use a screwdriver as a key!! (quite easy) or cut the wires, keep the light switch ON, and touch different wires (I think there is 3 wires: black red and yellow) until you see the back light flash. Or get a wiring diagram and connect + with -.
Old Nov 28, 2005 | 01:53 PM
ratkiller's Avatar
there is a fourth wire that is green is that gonna be a ground?
Old Nov 29, 2005 | 02:00 AM
1bad450r's Avatar
Not a good idea to talk about how to hot-wire something on an public thread. Contact your dealer about the key, they can help you out.
Old Nov 29, 2005 | 05:09 PM
ratkiller's Avatar
alright thanks
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
