2000 honda rancher ES
Old Dec 2, 2005 | 12:51 AM
bighodgey's Avatar
Default 2000 honda rancher ES
MY 2000 honda rancher ES is stuck in 3rd,tried to shift it with the emegency shifter it don't do nothing,i push the shift buttons up or down and the the shift motor makes noise but doesn't come out of 3rd,any suggestions
Old Dec 2, 2005 | 01:30 AM
IdahoVinnie's Avatar
I had that happen several times to my 2000 foreman ES. Usually it was due to a sticking shifter button. Sometimes I had to use the emergency shifter and rock it back and forth while trying to shift it.
Old Dec 2, 2005 | 10:40 AM
quicksilver's Avatar
first, it's better to try shifting with the machine actually moving.
second, make sure your clutch is adjusted properly. The ES system has a hard time shifting if the clutch isnt disengaging properly.
also, check the battery. have it load tested, and replace if necessary. the motor needs a lot of amperage to work with full power.
also check around the motor and the ANGLE sensor which is down by the motor, for loose or corroded connections. clean and put dielectric grease on the connectors.
Old Dec 2, 2005 | 01:17 PM
hondabuster's Avatar
If the tranny wont shift when using the handle, and youre rocking it forward and back...its got internal tranny issues.
What were the circumstances? Any strange noises, just before it happened?
Old Dec 2, 2005 | 04:33 PM
bighodgey's Avatar
I bought this off a friend like this,but he told me that they where going up a steep hill and flipped it back on him, i dunno much of if it made a noise,it says 3 on the gear screen not dashes.
Old Dec 3, 2005 | 08:42 AM
dzzy's Avatar
Hi Hondabuster...if it won't shift with the manual shifter, it's internal and not electrical. Very likely just the linkage though. Your next step is to remove (or have a shop do it) the front engine cover and inspect the linkage.
Old Dec 3, 2005 | 01:17 PM
Long time since ive seen you post. Hope its nothing serious.
I suppose now that the good weather is gone, and hunting is over, you have more time. Good to hear from you.
As always, youve got the right answer.
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
