why is it so hard to start
Old Dec 3, 2005 | 12:22 PM
warriorboy22's Avatar
Default why is it so hard to start
my warrior is starrting to **** me off i dont understand why i have such a hard time starting it. its pretty cold were i am like high 30s but i dont think it should be that hard i pull the choke out all the way it will start after holding the start button for a longer period then it should. Then it will start then run for a little then die then i have to do it again and it will stay on then i have to let it run with the choke wide open and keep it on for a few minutes then i can push the choke in but i have to stay on the gas every once and a while or it will idle low and die
also when i have the choke out as far as it can without pulling it out it revs real high then the carb make a clank kinda noise then stops reving then revs low the revs high then clanks that never stopps untill i lower the amount of choke how can i fix that i dont believe that is normal.
also whats the space for the spark plug
also the orange handle on the reverse lever is loose i can move it back and forth but cant figure out how to tighten it.
Old Dec 3, 2005 | 12:44 PM
89warrior's Avatar
I had the same prob on my warrior. All i had to do was rebuild the carb. now it runs like new. to have the carb rebuilt wae $130.00 so i just bought a 36mm carb from 36mm carb It cost me $194.00 it worth it!
Old Dec 3, 2005 | 12:57 PM
will that give me any horse power gains
and does it mount rite up no problems?
and do i have to do any jetting when i get it.
is it bad to run the quad with the carb needing a rebuild.
Old Dec 3, 2005 | 02:07 PM
89warrior's Avatar
yes if you have a aftermarket exhaust it will give you about 8 to 10 hp. depending on what exhaust you have. It comes with every thing you need to mount it. It is already jetted. No its really not bad to run you quad with the carb messed up.... but you will just have a hard time starting and keeping it running. i wouldnt live it like that if i was you. I sold my old carb on ebay for $100.00. so the 36mm carb only cost me $94.00
Old Dec 3, 2005 | 02:11 PM
thanks for all the help.
Old Dec 3, 2005 | 06:39 PM
fasterthanyou22's Avatar
wont hurt you?Yea it will bud.....It could blow the top end because a motor is tuned for a right amout of fuel/air intake and if it does not get enough then it wont run right and it will wear parts real easy.The engine will eventually seize up if you keep running it like that.
Old Dec 3, 2005 | 06:57 PM
Daniel631's Avatar
If your warrior is running lean due to a carb problem you can tear the motor up. It's going to run hotter than normal. You take the risk of burning up the valves and piston and warping the head.
Old Dec 3, 2005 | 07:13 PM
thanks im gonna order that white brother carb tommorrow then.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
