I hate jetting, please help me!
Full hmf on raptor 660
air filter adaptor plate and foam filter
475 ft above sea level
ok, now im confused are the 150/155 screws for example the same thing as fuel mixture screws?
if they are, i backed them 2.5 turns out and it is just compleatly cutting out on the mid range gears and top end at high rpm.
Where is the needle clip???
Originally posted by: Raptor0502
which one is the air/fuel screw?
Raptor0502 I think your a litte bit confused.
Main jets are a small piece of metal (usually made of brass) that go inside of the carb. You just take the float bowl off and unscrew the old jets and screw in the new ones and your done. Main jets regulate from about mid to wide open throttle.
ok, my problem was that i was that i wasent setting the fuel screw to the smoothest highest possible idle and then setting the regular idle. thanks
ok, one last question and then im good, are the 150/155 jets supposed to be turned all the way in
[img]i/expressions/face-icon-small-confused.gif[/img]..............Are you sure you can attempt this? Maybe you should take it to a dealer or a mechanic.
dude, wtf werent you watching me?? you always put the main mixture screws in all the way, and then you mess witht eh idle with that thing in the middle. What sizes did you get at columbia today?? Sry i had to work though..
