I hate jetting, please help me!
Old Dec 3, 2005 | 08:14 PM
Raptor0502's Avatar
Default I hate jetting, please help me!
Full hmf on raptor 660
air filter adaptor plate and foam filter
475 ft above sea level
ok, now im confused are the 150/155 screws for example the same thing as fuel mixture screws?
if they are, i backed them 2.5 turns out and it is just compleatly cutting out on the mid range gears and top end at high rpm.
Where is the needle clip???
Old Dec 3, 2005 | 08:50 PM
nmd3228's Avatar
It sounds like the bike is lean, not getting enough fuel. try uping the mains before messing with the air/fuel screw.
Old Dec 3, 2005 | 08:53 PM
Raptor0502's Avatar
which one is the air/fuel screw?
Old Dec 3, 2005 | 09:02 PM
maddog56's Avatar
the only one that you can adjust by turning and not replacing, and the only one you can get to without removing the float bowls. the mains probably need to be upped as the last member stated.
Old Dec 3, 2005 | 09:54 PM
Raptor0502's Avatar
ok, one last question and then im good, are the 150/155 jets supposed to be turned all the way in
Old Dec 3, 2005 | 10:25 PM
Doctorturbo's Avatar
GOT BOOST!
Raptor0502 I think your a litte bit confused.
Main jets are a small piece of metal (usually made of brass) that go inside of the carb. You just take the float bowl off and unscrew the old jets and screw in the new ones and your done. Main jets regulate from about mid to wide open throttle.
Old Dec 3, 2005 | 10:31 PM
Raptor0502's Avatar
ok, my problem was that i was that i wasent setting the fuel screw to the smoothest highest possible idle and then setting the regular idle. thanks
Old Dec 4, 2005 | 12:16 AM
BKrukow's Avatar
the eisiest way i have found to avoid jetting problems is buy a fuel injected machine............Sorry i just couldent resist.
Old Dec 4, 2005 | 12:27 AM
Ozark38's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]..............Are you sure you can attempt this? Maybe you should take it to a dealer or a mechanic.
Old Dec 4, 2005 | 12:53 AM
Z40005BR's Avatar
dude, wtf werent you watching me?? you always put the main mixture screws in all the way, and then you mess witht eh idle with that thing in the middle. What sizes did you get at columbia today?? Sry i had to work though..
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
