P650 fuel problem.
Old Dec 4, 2005 | 08:59 PM
Madcap's Avatar
Default P650 fuel problem.
Got snow today and went to plow the driveway. The quad is having a problem idiling. I turn the idle screw and it doesn't maintain the idle. It revs up like the gas valve is off and stalls. It won't start unless I crank the starter at full throtle. It will srart again and run fine then it happens again. I don't know where to begin. Any ideas?
Old Dec 4, 2005 | 11:43 PM
Rattlebars's Avatar
Might be the classic stuck choke which plagued the 02 p650. If your rear plug is fouled, almost a guarantee that's what it is. Idle screw on mine was useless as well... had to cut 1/3 off the spring to make it work.
Chet's Prairie
scroll down to choke.
Old Dec 5, 2005 | 09:35 AM
Madcap's Avatar
Thanks Chet, I just changed the spark plugs an they were both black. What do I have to take apart to do this?
Old Dec 6, 2005 | 02:14 PM
Hayashi's Avatar
Follow the choke cable to the carburetor. Make sure they are routed in a way that the choke operates freely without any sticking or binding. Pay special attention at the bend where one cable becomes 2 cables. To be sure, disassemble the choke plunger parts and watch little plungers moving freely as you open and close the choke.
PrairieDog126
Sep 12, 2015 06:53 PM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
