Air Leak or Jetting????
Old Dec 7, 2005 | 03:01 PM
atv087's Avatar
Default Air Leak or Jetting????
89 blaster 240 fmf pipe power reeds when tors unplugged idle races when tors plugged in wont idle at all
Old Dec 7, 2005 | 08:15 PM
badbanshee01's Avatar
on my banshee i'm pretty sure i have a airleak because it is doing the same thing your's is, it is idling out of control by itself!! there are alot of posts if you do a search also, just search for air leak. hope this helps
Old Dec 7, 2005 | 08:27 PM
enFORCER's Avatar
Sounds like your slide is stuck open... Take your air box off and look in the carb......
Old Dec 7, 2005 | 09:14 PM
atv087's Avatar
fixed it the throttle cable was routed wrong so it was pulling and the tors noticed the throttle was pulled like half way and that the button was in and it was killing the spark
Old Dec 7, 2005 | 09:25 PM
warriorryder's Avatar
don't forget to adjust your idle and adjust the screw on the tors unit....when you are adjusting it rev it and make sure it revs all the way with no stutters
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
