where 2 get stator?
Old Dec 8, 2005 | 08:49 PM
flashlight's Avatar
Default where 2 get stator?
as the title says
where could i find a cheaper stator that the $490 stator?
for a 2001 ds 650
Old Dec 8, 2005 | 09:29 PM
Majorecho's Avatar
check your pm
Old Dec 8, 2005 | 10:32 PM
rescuediver's Avatar
I've had good luck with rickystator[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 10, 2005 | 03:28 AM
azsandrider's Avatar
Call Kelly at KMS Performance. I just got my 410 watt stator on my DS 650 to run more lights. Cost was real reasonable.
(602) 442-4340
Old Dec 10, 2005 | 01:24 PM
flashlight's Avatar
There in AZ? Im from az too. was it less than 300?
Old Dec 10, 2005 | 01:28 PM
JSsDS's Avatar
Whats wrong with yours?
Old Dec 10, 2005 | 02:21 PM
flashlight's Avatar
not actually sure yet.it may be just a wire, but the battery keeps dying. just got a multimeter to check output of stator. then going to check over all wiring to make sure that it is not the stator. Just want to be able to find a stator if need be, That wont break the bank.
it isnt actually my Bike, but a good friend of mine. I ride a Banshee and dont have this charge problem.
Old Dec 10, 2005 | 03:25 PM
Majorecho's Avatar
flashlight - The stators are pretty robust on the DS and there have been very few failures that I'm aware of, if you need a stator I know of one for cheap.
Old Dec 10, 2005 | 10:25 PM
ERBEDS650's Avatar
I picked up a F650 GS stator off of E bay for 60 bucks, but now Im being told that I need a new rectifier becuase of the output of the stator is 400 watts.
Old Dec 11, 2005 | 12:22 PM
JSsDS's Avatar
Flashlight,
Major is echoing [img]i/expressions/face-icon-small-blush.gif[/img] my sediments on the stator which is why I asked the question. To help with your diagnosis, I have posted the test procedure for the stator on here a few times before. If you do a search you should be able to find it (if you need it). Most often though, its a bad wire connection, battery or the regulator/rectifier that goes bad. Good luck
