Plowing snow w/ a 2wd Scrammy
Is this even worth a try? Normally I would be plowing 5" to a foot at a time. 150 foot long gravel driveway. Will this even be worth it on a 2wd? I could chain up the rears but I wonder.
Thanks.
Hello Enigma.. Yup.. I plow with a Trailblazer. I run chains on the back and I have plowed 10 inches in a single pass. Seems to me that a 2wd quad is no worse than a garden tractor with a blade.
Bryce
Bryce
If Bryce's trailblazer can plow 10 inches of the white stuff, you should also be fine. Stick with a 48" plow, tire chains, and extra weight, and you should be just fine. If it's heavy, wet snow, just don't try to take as wide of a swath of snow. Keeping your speed up a bit will help kick the snow out more, hence, less snow to move on the next pass.
Bryce-
Not to hijack the thread, but how does your Wrangler pull that enclosed trailer with 2 ATV's? Does it have an automatic or manual? What gears?
Bryce-
A 2wd should be fine for light snow, just do like everyone else said -- add weight, chains, and air down the rear tires a bit (but keep the fronts nice and firm).
I think I asked bryce the same question last year. But I wasn't asking about the power, jeeps have a lot of torque; I was wondering what keeps the trailer from pushing the jeep on corners and braking -- they have such a short wheelbase, they are only rated @ 2000 lbs towing, while a cherokee with the same engine and driveline is rated @ 6000 lbs.
Bryce
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
