throttle adjustment on 400ex
Old Nov 4, 2000 | 09:09 AM
wanta400ex's Avatar
When i was looking into buying a 400ex i remember reading about a throttle adjustment to get more power. can somone tell me how to do it
Thanks
Nate
Old Nov 4, 2000 | 01:19 PM
hot_shoe_cv's Avatar
I'm enclosing a file which should answer your question. If not You can email me:
I have answered this question many times here, but since it keeps coming up so here we go again. First of all, to see if you even have any slop, try opening the throttle slowly to see if there is any free play before resistance is felt. I run a twist, but the thumb would still reveal any slop. If more than just the slightest bit of free play, your carb slide is not rising completely, thus reducing the fuel flow. If such is the case, with the bars straight ahead, slide the rubber boot back away from your throttle adjuster in order to access the adjuster lock ring. Turn the lock ring counter-clockwise to loosen it. Then, back the adjuster on the cable counterclockwise, AWAY from the throttle slightly (1/4 turn?). tighten the lock ring & start the engine. It should be at normal idle. If not, you need to turn the adjuster back IN slightly and re-test the idle. If normal, then the final test is done with the engine still running, by turning the bars to full lock in both directions. If RPMS do not increase, you have the right amount of slack. If they do increase you still have the cable too tight & need to turn the adjuster in slightly again. The cable should be adjusted so that it has just enough play to allow the bars to go full lock without opening the throttle, thus preventing any exciting surprises in hard turns.
THE AZ HARD PACKER,
Yahoo IM, aol IM..user name hot_shoe_cv
Save the public land FOR you, not FROM you..join the Blue Ribbon Coalition today! @ www.sharetrails.org
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
ghost civic
Jul 30, 2015 04:09 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
